My cruise doesn't work and I want to fix it before a long road trip coming up. Could someone post a wiring diagram or tell me the colors of the steering wheel switch cruise wiring?
My 98 failed on the self test, I get nothing at all so I want to start with the on/off switch with this test assuming its valid.
Key ON, Meter on 20 volts scale:
Check from switches line to ground. When you press the ON switch you should get anywhere from 7 to 14 volts on the line.
If not OK, check the 12 volt feed that comes through the horn relay up to the wheel. Also check the appropriate wires for continuity.
