Cruise Quit Working
Otdrzman
VA
Hey Everyone. Im new to the forum although i have checked it out a few times throughout the last couple years. Im having a issue with the cruise in my 07 expedition. It isnt working at all. Does anyone have any experience with this issue? Any help is greatly appreciated. Thanks
stamp11127
Temple, Georgia
First step is always check the fuses. If you have a test light that makes it quicker and you don't need to pull the fuses.
BIG GREEN FORD
loxahatchee Florida
My f150 2006 did the same then my tail lights went out changed the brake pedel sensor and it fixed the cruise control as well... Hope this helps
B
bedrck46
I agree with both of the above
But I would start by checking fuses first.
Although the problem could be related to the brake pedal sensor there are also many other components in the cruise control circuit that are not in the tail light circuit, that could be the cause of the problem.
Anytime there is a problem in an electrical circuit it is always best to start at the source of power (fuse) and systematically work thru the circuit till the problem is solved.
