350jeepcj5
Well, i have a problem. about 2 months ago i replaced all 8 spark plugs and all 8 cops on my expy, went on a 600mile round trip through the mountains pulling a trailer and everything went beautifully. Fast forward to now, my wife told me the other day that she was on her way home and the expy started to shake/miss, but went away. I didnt think much of it because it was late, so i left it go. Next day she calls me on her way home same thing, except this time i got a code, cylinder 4 missfire, clear the code everything was ok again. this morning go out and start it up, its is missing bad. So i pull the coil off and pull the plug out everything looks okay. I went to the store and exchanged that coil for a new one also bought a new plug because they are cheap. Reinstalled, same thing. With it running i can pull the coil wire off of cylinder 4 and notice hardly any change, pull it off of any other an i can hear a noticeable difference. So where should i start now? Get a noid light and check to make sure the injector is firing? Check to make sure coil is firing? Th way it was intermittent makes me think it is not an internal issue, am i right to think this?
