Besides unhooking the neg cable is bs, if the positive cable touches ground it will still short out or if you touch the cable then ground it will still soark
Ground as in anything else metal on the vehicle
The starter ground itself through its mounting surface to the block
Your neg cable goes from the batter to a body ground, then a frame ground the. To a bolt on the block
Positive has a lead to both sides of the fender solenoid, a big and small to the starter and a 6 gauge to distribution and alternator
Unhook the positive when checking connections, unhook both if your ohming out a wire or you'll be buying 26.00 dmm fuse
sent from my mind via of telepathy
