Dim instrument panel in daytime
R WHITENTON
Georgetown texas
I have a 2012 expedition EL in the instrument panel is so dim I cannot read during the day. The service man at the dealership said he could see them just fine. Other people agree with me.
Don Hall
SANTA CRUZ, CA
MAY HELP (?): https://www.capitolsubaru.com/service/information/why-vehicle-dash-lights-are-out.htm
ALSO: Why are my dash lights dim?
Your alternator might be going bad if your headlights and/or dashboard lights start to flicker and become dim. Once the dash lights or headlights dim, it is a clear indication of alternator malfunction. You may also notice that your power seats and windows will start working at slower speeds.Feb 28, 2017
PLUS: Put the key in the ignition and turn it to the “on” or “accessory” position. Then, turn on your headlights. Locate the dimmer switch for your lights. Most vehicles have a dashboard light control switch that will dim the dashboard lights as well as turn them off.
ChrisRCNY
Auburn, ny
I keep too much junk in my dash tray, I've had stuff slide over the sensor, drove me nuts until I notice it. I wish there was a Forscan setting to change the dash brightness ratio, given that I drive around with headlights in all the time.
