panda24619
i can do that! sounds funn! haha but they sure do look stuffed. now nvy can do it since he has a 4" lift.
Panda, I see you have aftermarket wheels. How wide are the rims? What is the backspacing? LIke I said, you don't get things just so, YOU WILL HAVE RUBBING!!!!!!
IF you think that running 37's with a 4" lift is impressive, I have the works on how to fit 40's with only a 4" lift and "SOME" body work or adding in a 3" body lift and then trimming the fender wells a little bit. But, that is something I am pondering and unless I change my mind to keep the truck for a lot longer, I am not going to do it. The big thing that would make the modification expensive is that I would also have to do a solid axle swap due to the size of tire and the stresses that they would place on the front hubs. But, you never know.
na man he got painted stock 16's![]()
Nuts you need to do a little trimming. My tires dont rub at all, even at full flex. The only thing i trimmed was an inch off the lower front plastic valence. I did it at an angle and you cant even tell it has been cut.
I'm new to the forum and have just recently bought a 2000 expedition 4x4 xlt. This is my first 4x4 and I had a few questions. First off, I wanted to put 36" tires on it so would a 3 in lift provide enough clearance without rubbing? Would a suspension or body lift be suitable? I'm not doing too much off roading..
Also what tires would you recommend? I'm looking for a good all season tire. All input is appreciated
any all terrain is a good tire. and for 36s i would do a 2" suspension lift. torsion crank and 2" spacer and do a 3" body lift. itll fit 35s with little to no rubbing. and 36s might rub. so trimming might be needed.
From my experience with a 4" lift, 315/75R16's are as big as you can fit without any modification if you are using an 8" wide rim with 4.5" backspacing. Going with a wider rim will result in rubbing, but this can be overcome with modifying the rear of the front wheel wells and trimming the front valance some. STepping up to 36's is most likely going to result in rubbing unless you do a lot more. Now, this all assumes no rubbing under any condition. Sure, I am running 37x12.5's and I have done a significant amount of modification and have a very specific setup that only works as I have it. Any change and it wouldn't work. Going with a rim wider than 8" with any 35" or larger tire is that the tire will start to rub on the outside edge of the rear wheel well unless you have adequate lift. For a 35" tire, that is atleast 4" of lift. I tuck my 37's by 1" with only 4" of lift.
Hopefully this gives you an idea of what needs to be done. IF you have more questions, just ask.
Thanks if it takes a great deal Of work to jump to 36" then what would be needed to atleast set to a 33". Would you recommend a 3" body lift? I am not familiar with back spacing and those terms, what does that mean?
Dont shy away from the big tires that you want. 33's will fit stock. Thats what my parents had on mine before they gave it to me. Just crank your torsion bars, get 2in. rear coil sspacers and do a body lift and it will fit 35's with ease. For tires i recommend ProComp Xtreme all terrain.
there are a lot of people on here with the 3" BL and coil spacers on 35s... Lane24 and DGray69 are two that come to mind... I know there are others...
a body lift is not the most difficult lift, but you would need tools, some mechanical knowledge and at least a full day or two to get it done... spacers are a lot less work..
but I second the ProComp xtreme ATs I love mine... but they arent the cheapest tires
The only reason I wont lift mine is because I'm trying to squeeze out the best mpg possible. With gas prices going over $4 this summer I have no choice...
we are already at 4$ in NY... thats why I drive my 02 neon...lol![]()
