Driver Seat
jphelps44
Lincolnton nc
This may be already listed here I searched for about 30 minutes and couldn't find any info. Is there anyway to turn the feature off where the driver seat moves back-and-forth as you put the key in?
B
bedrck46
would help to know what year your expy is
you may also want to read your owners manual to see if the procedure is in the manual
spotdog14
Haslett, MI
I think this is what you are looking for:
Easy entry/exit (if equipped)
This feature automatically moves the drivers seat backwards for easy exit
from the vehicle.
1. To disable/enable the easy
entry/exit seat feature, select this
function from the SETUP control for
the current display mode.
2. Press the RESET control to turn
the easy entry/exit ON or OFF.
J
jphelps44
Lincolnton nc
Thanks
I checked the manual could not find it going out there now just got it yesterday. Its an 2007 eddie b EL i just figure i should turn this off im 6'7 320lbs im scared its gonna wear the seat out
B
bedrck46
saves him the trouble of reading his owners manual
Look between pages 110 to 123
B
bedrck46
Mine was on 137.
and yours is a 2008 and his is a 2007 TWO different owners manuals and would also depend on which printing of the owners manual as there are at least 3 printings of the 2007 manual Ford is well known for making changes from model year to model year and even within the same model year
What I was trying to get at, is many times the answer that someone is looking for is in the manual all they have to do is read it.
