driver's side brake line broke, right rear has to be bled?
98eb5.4
s. ontario
pretty sure one rear wheel will have to be bled along with the left front?
might be lucky and just have to do the left front? tia
JUST4FUN
Admin
Moderator Administrator
Il
Right rear then left rear then right front then left front always longest run to shortest on the brake lines to bleed them
98eb5.4
s. ontario
i think that is a procedure (full bleed) when bleeding ifrom a fresh start, like changing a master cyl,
when only one half of the brake system is breached, thought that meant at most, 2 wheels having to be bled, or any wheel associated with the affected side of the master
dunno if it's diff these days but i'll start lf then rr
i was surprised to have been able to unscrew the steel brake line at the flexhose (that then goes to the abs unit), as well as the bleeder at the caliper, the abs brake line looked original
lotsa penetrant and a propane torch were enuff though the screw/nut is still seized to the steel brakeline, ended up getting it off by turning or using the flexhose to unscrew that connection
98eb5.4
s. ontario
ended up changing the flexline and just having to bleed the left front
