Ecu pin out diagram
Nikko84
Nikko84
Kaukauna Wi
Alternator. My battery light is on and it says Check Charging System in the info screen. So I was going to check the three wires going to the pcm from the plug.
Hamfisted
Ft Lauderdale
How old is your alternator ? With the engine at idle, what voltage are you reading at the battery? Should be 13.5 - 14.0 volts.
If you recently replaced the alternator, did you use a 110 amp alternator from NAPA or Motorcraft ? Don't use one from O-Reilly's or Advance Auto, they're garbage. Don't install a 135 amp alternator unless your Expedition came from the factory with navigation. The "Check Charging System" message is common when people install a 135 amp alternator when the PCM expects to see a 110 amp alternator.
2003 Expedition Alternators at Rock Auto
  • 2003+ Expedition - Charging Circuit.pdf
