Mediamonkey11
So I converted to electric fans using the Windstar setup, so far it works very well only running off of one fan!
But, the large fan I'm assuming is a 2 speed fan, it has a 3 wire plug, when applying voltage to each of the positive leads, the fan will run, but will run at the same speed on both.
The funny thing is when I applied voltage to the single speed smaller fan, it seems faster than when I applied voltage to either of the windings on the large fan…
Is the second winding a spare? How do I achieve the higher speed, put voltage to both at the same time?
