Engine Is Sputtering
Phyliss Causer
Philippines
What causes engine sputter? I know that an engine running out of gas will definitely sputter but if the gas gauge indicates full, what could be the problem? does it require immediate attention?
JasonH
Houston, TX
Could be many things. Maybe spark plugs. How many miles? Can you read codes using torque? It would let you see octane adjustment and other useful info.
Plati
Yes. ... and gas gauge could be wrong.
Many things could be root cause but on the fuel topic, when was fuel filter last changed?
anionka
United States
One of the most common causes of a sputtering engine is an issue with the vehicle’s fuel system—the filter, pump, and injectors.
