Error codes and error codes and more error codes
billycuth
Southeastern PA
I'm not sure I'd replace the injectors at my cost when those are warrantied parts for another ~25K miles. But that's just me.
G
gigantapithic
Calgary
small block or short block? small block is what we all have in the expeditions. its a 4.6 and 5.4 motor. ford really doesnt have a big block anymore....
short block is if they are replacing your engine, the short block is the engine block with crank, pistons, connecting rods etc, just does not have heads, intake or any accessories. that would be a long block if they came with it.
Short block :)
Well the other option would have been to refuse to pay for them, at which point the dealer would have said "we've documented this as requiring replacement due to wear" (remember the extended warranty is because they may stick open or closed, not from normal wear). Once they've told me they need replaced "due to wear" they've pretty much covered their collective a$$es in case it happens again. By the time the car comes back I'll have been without for 26 days and considering the damage that one broken fuel injector caused, I'm not about to risk it happening again just to argue over a few hundred dollars.
G
gigantapithic
Calgary
Short block :)
The risk/reward simply isn't worth it.
sharprd65
