supermario
Hey Guys, I started to drive away from my home last night and my 97 4x4 5.4 Expy just shut off, no warning, no shaking, just turned off. It will crank and crank but doesnt start. I have fuel in it, i tried the fuel pump reset switch and still nothing. I ran diagnostics and there were no codes found, then i did another extensive search and code P0232 (Fuel Pump secondary circuit high) code popped up. There is no check engine light on.
Anybody ever have this problem. I dont know how to test the fuel pump, i was gonna just try to unplug line by fuel filter to see if pump is working but not sure if that will help. I also read that there is a fuel pump sensor?
Any help would be appreciated before i tow my Expy off to the mechanic. I already bought the fuel pump with strainer/filter thing.
Thanks.
fyi, 2 trustworth mechanics have said its common for fuel pumps to go out. This same thing happen to my altima but it was a crank sensor.
Thanks.
