First oil change 1500, then every 3,000 regardless of the oil life percent reading. I never drive the truck until the engine oil temp is "normal". Added the catch can. From what I understand it is not needed with the newer gen 3.5.
This is what I did... but I had them come and get it and do it. I waited until I needed a wash as well since they do that with any service. I thought I’d miss doing the work myself but not so much, I still turn wrenches but it’s more on my terms now and it’s a lot fun for me this way.I normally do my first oil change at 1000-1500 miles. I just picked up my Navigator a couple of days ago. I may do my first oil change on this vehicle based on the oil life and change the oil at about 20% used.
Your owners manual, breaks it down into 3 service levels. 10K normal, 5k severe(short trips) and 3K extreme/towing. The factory 'fill" oil may have break in additives and probably, little detergents. If its a lease, wait a while on the first change. If its one you will keep 'forever', I would change around 3K. Rental car companies, leave the factory oil in to the max. I don't think the engines blow.
New engines use an additive that hardens wears surfaces and suspend particles. I believe it is zinc phosphate, paraffin and molybdenum. Break in oil has no detergents, because there is no sludge or tarnish. Its new. Quaker State is known for high paraffin.What sort of break in additives and/or detergents?
