forscan as built IC on a vehicle (2013-2014) with OEM Trailer Brake Controller
Caymran
Anyone on here have an as built table for Gen 3 Expy's?
Or are they cross compatible with something else?
Specifically looking for as built IC on a vehicle (2013-2014) with OEM Trailer Brake Controller for comparison to mine.
Thanks.
2012 Expedition no TBC
ICM 720-01-01 9105 7DFF 3B
ICM 720-02-01 3146 4D4A 558D
ICM 720-02-02 3241 3533 454B
ICM 720-02-03 4546 3537 3255
ICM 720-02-04 3934 9A
ICM 720-03-01 0E39
ICM 720-04-01 002C
ICM 720-05-01 D400 01
2014 Expedition with TBC
ICM 720-01-01 9105 7BFE 38
ICM 720-02-02 314A 3530 434E
ICM 720-02-03 4546 3634 3051
ICM 720-02-04 3634 97
ICM 720-03-01 0E39
ICM 720-04-01 002C
ICM 720-05-01 C400 F1
Diffs
ICM 720-01-01 9105 7XFX 3X
ICM 720-02-02 3X4X 353X 4X4X
ICM 720-02-03 4546 3X3X 3X5X
ICM 720-02-04 3X34 9X
ICM 720-03-01 0E39
ICM 720-04-01 002C
ICM 720-05-01 X400 X1
C
Caymran
Correct. As-built can be pulled from ford with a VIN, and is specific to the vehicle as it came off the line. I am adding aN oem trailer brake controller to my 2012 expy. It was not an option until 2013+, 2012 and back were aftermarket only. I wired in the oem tbc to the appropriate connections and the can bus, and was seeing if I could enable it: it looks like I may have to do a console swap as well or just the IC.
I’ve been poking around in forscan and found the language settings, which is associated with trailer gain for the f150.. but can’t get gain enabled; just sway. I found other things, like front parking sensor, compass stuff, automatic step rail, etc.. The default, just click enable .. is not there for the tbc in IC although the module does show up.
DeafBringer
Washington
Did you ever get this sorted?
