Stotadude
I have about 70K miles and I've noticed recently I get a nasty smell (like cow manure) when it first starts but then it dissipates. Any ideas what it is and how to get rid of it?
Ah yes....the trusty dusty "whats on fire!" smell.Along with the burning off dust smell when you first run the heater.
Yep. ANd it doesn't hurt to run that hot air through as many air ducts as possible. Don't forget the rear unit, either.bobmbx
I leave my heat/ac on auto at 70 most of the time. Are you saying to kick up the set temp as high as it will go and run it for 15 minutes?
Ok, thanks. Will get on that tomorrow.
Inside or outside? Ventilation system on or off (heat or AC won't matter at start)?
I'm guessing a moldy evaporator. Virtually every AC evaporator will produce that smell over time, and in cars its usually around late summer/early fall when people notice it the most. Sometimes the cure is as simple as letting the engine warm up and then blasting the heater at full for 10-15 minutes to kill the mold/mildew on the coils.
There are several products made to disinfect AC vent systems in cars. Most involve spraying a thick, foaming substance into the dash vents and letting it soak for a time. I've never done that so I can't recommend any specific brand.My first Expedition, a 2015 with 90K on it, starting putting a nasty smell out of the vents a few weeks ago. Dealer tried telling me the smell was from the evaporator core leaking refrigerant. They’d be glad to rip out the dash and replace the evaporator core. They evacuated all the refrigerant and the smell is still there so I’m not buying that it is refrigerant. I tried running the heat on high for hours. That seemed to dissipate it, but it keeps coming back. The smell is foul and sickening – I can buy into the idea that it is some sort of mold/mildew. But then again, I ran Town Cars and Crown Victorias for years and never had any smell coming from the vents. Any thoughts what to do about it?
Ozone generators ionize airborne particulates and cause them to drop to the floor. Thats how they eliminate odors. They do nothing to the mold farms in the AC system.Ozone generators work pretty well and there are quite a few cheap ones on amazon. Leave HVAC on recirculation for a bit to get it all through the system. An hour or two makes quite a difference. I've used them successfully along w deep cleaning interior to virtually eliminate smoke odors from vehicles which is one of the harder things to eliminate.
Don't do this. It is too harsh. Spray Lysol were the cabin filter sits. It will get sucked into the system with the fan on high. Its the cheapest and easiest, I have found.There are several products made to disinfect AC vent systems in cars. Most involve spraying a thick, foaming substance into the dash vents and letting it soak for a time. I've never done that so I can't recommend any specific brand.
As a last resort, take a drive to Death Valley and let is sit out there for a week. That'll kill just about everything in the car. Since you're from PA, I would say you don't get a lot of super-hot days to keep the mold at bay like a car in GA or FL does.
I would turn off the AC compressor (to stop the condensation from occurring), make sure the "Recirc" mode is off, windows cracked open a bit (all the time) and keep the fan on whenever you're driving. The idea is to dry out the mold. Hope you're not allergic to it.
Not sure where your blower is, but if its in the engine bay, you can pull it off and expose the evaporator coils (they should be right there). Douche it liberally with Tilex bathroom cleaner. The car will smell like hell for a few days but I've found nothing better than Tilex to kill mold and mildew (except fire).
Worst case: It never gets better and you end up selling the car.
Uh. No that’s not all they do. I use one. A commercial grade unit. You cannot be in the same space that it is running in until the unit is shut off and the ozone has dissipated. Ozone absolutely destroys mold and will fix the problem. Ozone generators are used to purify the bloodstained carpet of crime scenes and remove carpet odors. Theres way more going on than just dropping odors out of the air.
OP, seriously, if you can’t rid of the odor, try a commercial grade ozone generator. Not one of those alpine garbage.
