Big Jeff
So. First post and its a problem post for my 05 Expy.
Particulars... 05 Expo. 4x4, air suspension, 104K and change. Everything is still OEM except the sway bar links.
So I have been hearing a clunk in the drivers side front. Bumps, turning, heck even when I hop in to drive it. I just recently went and replaced the front sway bar links. So I hopped under there today to give it a good once over.
Sway Bar Bushings and links are still good. Upper control arms, tie rod end, lower ball joint. Air Bag suspension. All look good. No real play to speak of.
CV Axle boots look fine but I wiggled my hand in there and decided to see if there was any play. Grabbed the axle and could hear and feel play. Making a similar sound to what I had been hearing. Closer inspection revealed that where the CV axle bolts to the front diff has play and I can hear a clunk when I moved the axle up and down. So the cv axle AND where it bolts to the diff have a fair amount of play and you can hear it clunk. Sooo I am guessing its the differential carrier bearing???
Has anyone come across something like this before??? I've got 104K and change on it, outside of the sway bar links, all the wearables are still OEM in the front. I am thinking that it would be pretty weird that the carrier bearing would go before those..
Thanks!
-Jeff
Thanks!
-Jeff
