MidwestBoater
So, yesterday I replaced the gear oil in the front and rear diffs, did a trans filter service, and replaced the trans fluid in the transfer case.. That front differential is really not designed to be serviced is it? It has only a fill plug and even with my smallest tube on my oil extractor I could only get about half the gear oil out of it because the tube couldn't get down to the bottom of the housing. You can't remove the front cover unless you want to drop the steering rack. Major bummer.
