So based on some earlier questions I had, I went ahead and borrowed a fuel pressure gauge to check my pressures. Finally got time to start in on it, found the fitting on the rail, pulled the little cap off, hooked up the gauge and started testing.
Well, the gauge registered no pressure when I turned on the key. Tried several times, couldn't ever get it to register. Thought maybe the gauge I got was bad. Took it apart, made sure there wasn't a blockage. Then I realized I couldnt even get fuel to come out when I hit the little bypass button on the gauge.
So, I took the gauge off the rail fitting, and then with the key on and the pump pressurized, I used a screw and pushed the valve in. I got a tiny little drip of fuel, and then nothing. I could hold the valve in and no fuel came out. So, I am thinking that my pressure is so low that its actually not registering, but why isn't it at least putting out a stream when I open the valve?
The regulator and the check valve are all in the pump on an 03, correct? I'm thinking its way past time for a new pump. Oh well.
