Fuel pump going out?
08HybridOK
okc
Fuel pump going out? Longer cranks to start.
So after some searching, it appears my fuel pump may be dieing, it's been taking more cranks in the morning to start then normal. (Say normal was 2 seconds, now it's like 10). But if I turn the key to run for a few seconds, then start, it's normal again.
So what others say is it's the fuel pump (just replace the filter about a year ago).
They also say it's a $700-1,000 job at a dealer/mechanic.
So I go to Rock auto and there are pumps starting at $20 to $200, Oreiley has from $90 to $500!
I didn't think there would be such variety & confusion.
Which pump do I need to get, I can go with local stores, rock auto, amazon, etc.
It's a 2000 5.4 2WD, originally has the rear air suspension; but is now springs.
Thanks for any help, direction (And instructions?)
Temple, Georgia
The pumps I've bought from Rock Auto have been Denso or something like that. Still going strong. Why pay more than you have to? You may have to do very minor wiring changes due to different plugs the industry uses - just adding connectors mostly.
Biggest pain is the connectors used on the lines, you'll need the fuel line disconnect tools for that. You'll also need a set of stands to get it up in the air and another set for the tank. Impact tools speed up removal.
Let us know how detailed you want the step by step instructions. My expy is the 4.6 so I'll assume they will be similar if not identical.
08HybridOK
okc
Temple, Georgia
The only time I replace the pump and sender is when the vehicle has high mileage or there has been trouble with the gas gauge. If there hasn't been it is a judgement call if you want to replace it. On my personal vehicles I've only changed the pump.
I wouldn't trust the $20 pump unless it was a known name that was a close out special.
The video you posted is about right other than having a lift and the jack to support the tank.
FYI - have the tank as close to empty as possible so that it is easier to handle. Remember that you are working on a bomb of sorts once the lines are off and even more so once the pump is out. No sparks or you will have an exciting time on your hands.
08HybridOK
okc
I don't have a pressure gauge.
Once started it runs fine. It's just taking longer to start.
Bowesmobile
Clarkston, Mi
Sounds more like a fuel filter. Why go through a ton of hassle for nothing. Have you ever replaced the fuel filter?
08HybridOK
okc
I think it was just last summer, at most 8-10k miles ago.
Not sure if.when it was replaced prior to that.
If I buy a gauge; what should I be checking? I mean steps, a reading prior to cold start, while cranking or turn key to prime, etc?
It also only seems to be the first start of the day that's longer. I can leave it sit an hour or 2 and it starts normally.
plugs? It still has original plugs (86k miles so far)
Change filter again? Not even sure what brand I bought last year.
Thanks for the advise.
jbanks
McKinney, TX
I'm pretty sure you can rent/borrow the fuel pressure test kit from the major auto parts stores.
Fuel Pump Diagnostic Kit | AutoZone.com
I'm interested in this thread too. I have also started experiencing longer cranking time. At 155000 miles it seemed to just take a second or two crank. But now I'm at 163000 and it seems like i need 3-5 seconds to crank. I am wondering if it is the injectors bleeding down the fuel pressure and you just have to crank it a couple seconds longer to let the fuel pressure build up to an acceptable level.
Temple, Georgia
Hey look, we're men. Men love tools. Fuel Pressure gauges are a given for the tool box along with other chrome plated tools. Suck it up and buy yourself one for Fathers Day.
When you get over 50 like myself and go looking through your roller toolbox for a tool you need, you run across tools not only do you not remember having, you don't remember buying them. The problem comes with the third stage - not remembering what it is and how to use it. That is just around the corner for me.
Cycle your ignition to "on" 2-3 times without starting. You should hear the fuel pump whirring then stop during each cycle. On the 3rd cycle go ahead and start. This primes the fuel rail with enough pressure to start the motor.
08HybridOK
okc
OK, rented a gauge from auto zone; somethings wrong:
Screwed it onto the fuel rail (I assume, it was the tire valve looking thing on the steel rail on the passenger side behind the wires & hoses right?)
Instructions said to finger tighten; so I did, Off, gauge at 0, turn to run, still 0, start up, still 0????
So is their gauge bad, or did I connect something wrong?
Temple, Georgia
Gauge not tightened all the way on the valve or it is bad.
Try it in another vehicle if possible.
08HybridOK
okc
Update:
I didn't try gauge on my Hybrid; just didn't want to risk screwing it up somehow.
But this week it seems the big X is back to normal. Just a few seconds to start again. ????
