Has anyone else had the annoying infamous Ford fuse #10 issue? Your steering wheel button lights and shifter lights don’t work. You find fuse 10 blown and replace and get no change as well as not blowing again. There are thousands of threads about this online and it seems not one dealer or owner has found a fix. The only known fix by dealers and owners I’ve seen is to take a 10A fuse, bend it 90 degrees and jump out fuse 79 to 80 under the hood. Only issue is expys have 73 fuses there...I need to figure out what fuse 80 on the F-150 is to see if we have a similar to jump.
It seems many F-150s blow fuse #10 before they are bought off the dealer lots and the issue goes unresolved.
