FX4 front air dam
Red Raider
Southlake, Texas
I bought a 2019 F4 last week. It's my third Expedition but took a break between the first two and drove a 4x4 Armada before buying this new one. I'm sure this question has been posed many times but after about 20 min looking I didn't find a answer. I want to remove the air dam but don't know what you do with the part of the wheel well that no longer has support from the dam
shane_th_ee
Seattle
The attach points aren't actually on the air dam. See those 3 fasteners? You remove them, then remove the air dam, and then re-install the fasteners.
duneslider
Utah
I like the wheels on the FX4, looks good with the BFG's too. What size did you go with, same as stock? Did you lift it? Looks really nice.
Red Raider
Red Raider
Southlake, Texas
Yes on the lift. Stock on a FX4 are Michelin 275/65/18.
The KO2’s are 275/70/18. I'll be using the truck to haul clients around (corporate types), so wanted to keep it as close to stock as possible while maintaining my confidence to take it off road a few times a week during hunting season. I've used KO's for years in all conditions, I'm a big fan.
I'd like to know if I could get 305/70/18's on the stock wheels with the leveling kit. The tire dealer said they wouldn't fit but he didn't have them in stock and they are actually cheaper.
sjwhiteley
Kentucky
From what I have seen and read, if you go wider than 285 with stock offset (+44), it’ll rub on the upper control arm at full lock. I believe the 22s have 285 wide tires?
those KO2 tires do look good. How are they in the wet/light snow? That’s the biggest issue I have with the current tires - not a lot of confidence in their ability.
(Edit. Saw you are in Texas, so might not understand the meaning of the word ‘snow’...)
Lou Hamilton
Maryland
If you add a 10mm spacer, not adapter, you will still have enough lug bolt to use for the lug nuts.
I want to keep the stock 22" wheels from my Stealth since that is partially why I bought it. If I go with 305mm wide tires, they are 20mm wider than the stock 285mm tires. They add 10mm to the front and 10mm to the rear. Therefore, a 10mm spacer will bring the back of the wider tire to where the stock 285mm tire is.
Kids, this is why math is so important in school. LOL!!!
Shaffer9
Ms
Just curious, how are you verifying that there is enough lug to run a 10mm spacer on the stock studs. I would love to do this just want it to be safe.
Lou Hamilton
Maryland
In talking to some wheel guys, the Ford F-150/Expedition have 1.5" bolts. A 10mm is about 3/8 inch and will still provide over 1 inch of thread. This should provide enough grab for the wheels to safely stay on the vehicle. They said 1 inch would be the minimum amount of lug bolt they would allow before upgrading to longer bolts, which is also an option.
I don't think I would ever do any heavy duty 4-wheeling or try to drift with them in that state, but driving and towing under normal circumstances, I am willing to take that "risk".
OHIO
I have a 13 with the leveling kit and up front I will be changing out the UCA and going with Icons front coil overs (tighter coils) for clearance when suspension is fully extended. Right now the UCA hits the stock spring. The raptor wheels (315/70R17) on this configuration rarely rub maybe full turn going over a curb.
fxpedition
What lift is that?
No members online now.
rockinghranch
