I am looking to buy a 1st gen expedition 4.6L with 2wd. I will be using it as a weekday vehicle and drive my v6 mustang on the weekends. The suv will also be the tow vehicle for track days with the stang and long distance shows. You are probably wondering why about now on the mustang so here is it's background as well. I have also posted a few questions about my targeted suv in the 1st gen threads.
I started the build by designing and having a custom single turbo kit constructed.
In hopes of having this on my original engine until I found a new engine it took some time but decided against it and went and found a 2000 3.8l online to begin construction on.
A few friends and I worked to break it down and then after that it was pretty much me building the engine but a lot help came from my buddy that allowed me to keep the engine in his garage during this time.
Through a series of good luck finds I soon had a nice stream of parts coming in, heads, lower intake and rockers from hiposilver. The 4.2L kit and cam came from other users on a few different websites. Have to put in here that I mostly with help from a few others built this engine not from a shop.
The engine started coming together quickly until it sat for a few weeks waiting on the install day. Starting on a Wednesday it was back up and running by Monday.
Video of dyno times will be coming soon.
Some engine specs:
ARP head studs
218/224 .55/.55 114 lobe separation
1.7 stud mount roller rocker arm kit
Spec stage 3 clutch
Tial waist-gate
10lb spring
39lb cobra injectors
8.8" saleen rear
Vacuum Distribution Block
Svt ford focus fuel pump
T70 Turbo
UDP 01+
Catch can/oil separation
P&P lower intake
Stage 2 heads
4.2L stroker kit
egr block off plate
05 slot style M.A.F sensor
Sandwich plate
oil relocation kit
10" Slim fan x2
Accel coil pack
Some engine specs:
ARP head studs
Spec stage 3 clutch
Tial waist-gate
10lb spring
8.8" saleen rear
T70 Turbo
UDP 01+
P&P lower intake
Stage 2 heads
4.2L stroker kit
egr block off plate
Sandwich plate
oil relocation kit
10" Slim fan x2
Accel coil pack
More than a few in here that have built mustangs. For towing your mustang I would recommend a 5.4l expy as they are better equiped to tow. More torque and stronger tranny. The combo of the stang and trailer will likely top 5,000 lbs.
