Help!! 4wd won't disengage.
Declansdaddy
Va.
So last weekend I did the brown wire
Mod which went flawlessly. Today I had to use 4 low to pull a boat out of a rutted up field. When I got done I tried to put it back in (A4WD) which is 2WD with my toggle off and it won't come out of 4 low. Any ideas? I even switched my brown wire toggle switch on and the led didn't light up.
tonydiv
technical advisor
Middle River, MD
Put the switch in "2wd" and roll backwards at maybe 5 mph, then put the gear shift to neutral while you're still rolling back. It should disengage.
