fjordexpedition
Over the past month or so, I began to notice black spots on the driveway where the Expedition is parked. Given that the vehicle is a '21, the last thing I am expecting right now are oil leaks. I thought that maybe it was just the AC drain picking up some dirt on the way to the ground and did not investigate for a while. Today I decided to take a look as the spot appear to be getting larger, and thought it looked like far too dark to just be some dirty water.
After crawling under the vehicle, I see that an oil like substance is collecting along part of the exhaust, and I assume this is the culprit based on the location of the spots on the ground. The picture is looking to the rear of the vehicle. Any idea where this fluid would be coming from? The vehicle sits at an angle on the driveway, and it seems whatever it is, is either coming directly out of the muffler, or else dripping from above, pooling at the bottom of it, and then running back and dripping off. I am taking the vehicle in to be looked at on Tuesday, but would like to try to gain a little knowledge of what may be going on before I take the vehicle in.
