Help me decide what to do
JHolden
Maine
So I got myself a 2007 Expedition XLT 5.4L 3v (217k) for $2500. It was meant to me a upgrade on my 2004. However 6 weeks in I think I made a mistake. In the 2 years before it came to me its had $5300 of work done on it including:
4 Brand new Goodyear Wrangler tires
New Spark Plugs and Coils
Rear ball joints
New Fuel pump and filter
New serpentine belt and tensioner.
Front Pads, Calipers, Rotors
New Muffler
Front upper and lower ball joints
Since I have had it I have Welded the frame, Front Hub, Front Ball Joint, battery, Transmission fluid change (to fix the shudder). This weekend I will be doing Both Rear hubs.
further problems I know about but haven't tackled yet are
Needs a new TPMS sensor, and a universal joint for the steering column, I am missing a exhaust manifold stud.
Also when I started to replace the VVT solenoid but aborted that project as I found it wasn't needed (transmission fluid change). I now get the codes 0340 and 0344 that wont go away.
Did I buy a Lemon? what's going to go wrong next? I cant afford to keep throwing money at it. so should I sell it? or is there light at the end on the tunnel?
Thoughts to help me decide?
Adieu
SoCal
That's 5300 is really just $1k worth of parts... possibly less, if good takeoff wheel/tire combos would have been utilized
Why did you need to weld frame??
Your codes are hopefully loose or oxidized connections or frayed wiring
J
JHolden
Maine
The frame had a couple rust holes in the front wheel wells. in each wheel well there is a triangular plate strengthening a weld, Apparently its fairly typical that a rust hole forms under this.
Yea that plate rusts till it falls off, happens on alot of them.
Flexpedition
midwest
Not sure if I follow. You bought a 11-year-old vehicle with over 200K for $2500 and were hoping it'd be maintenance-free?
Most of what you listed (that somebody else paid for) gets replaced on everything at some point regardless of make/model. Tires, pads and rotors, batteries, fluids, mufflers, fuel filters, plugs, coils, TPMS sensors, belt and tensioner and so on. This stuff doesn't last forever.
However - hubs, ball joints, steering u-joint, brake calipers, muffler - not completely unheard of needing replaced or servicing eventually but considering the truck is subject to the climate you live in, it really comes as no surprise.
The previous owner took the beating and they'd probably still be driving it had they spent a little money with Ziebart, Krown, or bought car washes throughout the winter.
rollavvti06
minnesota
But even then 2500 is a steal around these parts... all 3rd gens are at least 5k around here with high miles. Some 2007, 2008 ive seen go for 10 grand
J
JHolden
Maine
No I obviously expect there will be maintenance there always will be. I am just wondering if this is typical. is it the good deal I thought it was?
Idk for $2500 bucks you can’t go wrong if it rolls forward...
I’m at 163,000 miles I’ve done new tires, all brakes and rotors, both rear wheel bearings, front ABS sensor, transmission fluid and filter change, radiator coolant change, replaced horn assembly, TPMS sensors, HVAC door actuator, 4WD solenoid, 4WD actuator, serpentine belt and tensioner, and the rear wiper transmission all in the last year.... while all this was not necessary as the miles rack up things come down the pipe and it’s best to keep up on it or the truck becomes a mess. Maintenance is a given as an auto ages.
If you read our forum, and I hope you do, you know that 2005-08 models are either great, or problematic. Basically you jumped into this deal without a mechanical, and body inspection. If all is fixed for now, you can put it on trial. You can always bail, if it gets bad. I bought a 84 Lincoln Mark 7 that had a stack of repair papers from previous owner. On top of that, 3 weeks into purchase plastic timing gears stripped out, man I was pissed! After that, turned out to be a great car. Kept 17 years! Cried when I drove to buy back wreckers. Breaking up with hot girlfriends didn't hurt that bad!
John Christopher
CT
False. I don't know how you could think that all those parts would only cost $1000 especially since you live in California. They are probably worth $1500 or more.
John Christopher
CT
If the motor and trans are in good shape, I would keep the truck. With what you paid and everything that has been already repaired your ahead of the curve.
Plati
Here is what my 03 XLT cost me in repairs over the years. Didn't include tires but this is everything else. Before 2007 it was pretty much warranty since I bought it new. Some work I did myself and some had a shop do. average $820/year
2018 --> $388
2017 --> $784
2016 --> $751
2015 --> $1917
2014 --> $60
2013 --> $337
2012 --> $444
2011 --> $41
2010 --> $2709
2009 --> $45
2008 --> $1820
2007 --> $546
A wise man once said its gonna run you about $1000 a year in repairs.
The thing is a rust bucket now and I need to carefully consider how much its worth before I pump any more cash into it. Any repair more than what its worth "aint gonna happen". I'm not really sure what its worth though so thats a puzzle.
J
JHolden
Maine
Thanks for the input guys, this is the discussion I was looking for. I was at a low point and questioning my decision to buy. It always takes me a few weeks to trust a new car and to figure out its rumbles and rattles. I think this relationship just got off to a rocky start.
J
JHolden
Maine
Moose, I am fairly new to the forum, its like drinking from the firehose of knowledge for these trucks.
3 1/2 years back I was the new kid here myself. Give it a month or two, before you decide. If it turns out your not in love, but just had an expensive fling, those can be fun too! Then do like you would to a bad date, give the old girl cab fare, and say goodbye. Cars like women are just around the corner, looking for someone to take them home!
bobmbx
:eek:
I love this forum
lvcjt702
Lost Wages
Wait!
Was this a purchase or a rental?[emoji848]
Sent from my SM-G935P using Tapatalk
Could be worse, we could be an old British, or Italian car forum! Nothing hotter but what a pain, a 1960's Ferrari, or a 1960's tall brunette from Italy. Both worth the trouble. The Ferrari singing at 8,000 rpm the brunette on your arm when you show up in the Ferrari at your 40 year high school reunion!
humper
florida
Rear ball joints
New Muffler
