HELP! Mechanical Rumble-Buzz when turning Right
nochruto
IL
Hey guys wife mentioned to me the car sounded weird and so i took it out and when turning right sounds like a low rumble at low speeds but higher pitch at higher speeds. Sound appears to be coming from the front left and turning the wheel Left even a few degrees the vibration/sound goes away. It’s pretty bad now that at low speeds i can feel it through the pedals. A quick search suggest it maybe the wheel hub. Can anyone confirm this and is this something one should try to tackle on their own? BTW, car is a 2016 Limited EL 4WD and issue is occurring regardless what mode I put it in.
99WhiteC5Coupe
You might want to post the year, make, model, engine and if 2WD or 4WD (and what mode you are driving in).
