Is it a 4x4 Expy ? Does the other end of the line go down to the front axle ? It may be the axle vent, and it just needs to be secured to the brake line coming off the Master cylinder.
Well, it should be connected to the front axle, just secure it with a zip tie, so it's not flopping around and rubbing on the exhaust manifold. That end should just remain open so it can vent.
Are you getting a check engine light? or any DTC codes with these random stalls ? I'd recommend a smoke machine and smoke test the intake system for leaks.
No. No CEL, just pulling away from a red light, hit gas, stall. Usually starts right up.
Has happened maybe 3-4 times the last month or two. Investigated online and ordered a new evap purge to swap out and see if it helps.
