I just got finished explaining this one to my friend who's addicted to buying those stupid octane boosters for his stock car.
For an engine made to run on 87 gas, putting in a higher octane will not only have no extra benifits, it can also cause negative affects.
"WHAT IF I PREFER TO USE GASOLINE WITH HIGHER OCTANE RATINGS?
You can, but there are no real benefits, other than the gasoline manufacturers making more money off of you. When you use a fuel with a higher octane rating than your vehicle requires, you can send this unburned fuel into the emissions system. It can also collect in the catalytic converter. When you over stress any system, it can malfunction or not do what it was designed to do properly. In the early 90's, an early warning symptom was a rotten egg smell from the tailpipe. Easy fix, go back to using regular 87 octane gasoline. The rude odor usually disappears after several tanks of gasoline. "
http://theserviceadvisor.com/octane.htm
If you google it, all the sights will tell you the same basic thing - put in the recommend fuel and don't waste your money.
