So I fish tailed on a right turn and my driver side wheel smacked the curb. I'm sure something bent....
The rear alignment specs on that wheel was like 5degrees of toe in and 1.5 degrees of positive camber.
I was able to adjust to shorten the tie rod to adjust to toe. But the positive 1.5degrees on camber I have no idea how to fix. All the components look so beefy it could be anything. how do adjust that camber in?
If I added the pic correctly, you can see in the pics, barely but noticable the driver side rear camber is a bit off.
