Hot Starting Issue
rollingbear
crestline ca
Hay Everyone,
I am having a hot starting issue and I am hoping some one can help...
been going on for a few months, but it is getting worse now. It started where it would not start after being driven for a long while on a hot day and then being shut off for about 15 mins (like to run into the store). it would start and stumble at very low rpm (like 400-600rpm) but wouldn't rev up. then i would try and start it again and it would only crank like it was out of gas. but leave it set for 2 hours and it will start right up and run fine. But it would start fine as long as the outside temp was under 95 degrees. now its getting worse and will do this at lower temps too. same thing cranks but wont start and sometimes low stumble and then no start.. cool it off and starts right up.
Had a friend that said he had similar problem and it was his crank position sensor ..so replaced it with a new wells part and still same problem.
have done lot of searching and read a few people with same problem but no resolution
any help would be great.. thanks
