I greased the caliper bolts ??
Jexpy97
Merica
I greased the caliper bolts that go into the guide pins to attach it to the caliper.
I used syl-glide.
Is that wrong? When I pulled out the bolts there was what looked like grease on them so I just assumed regrease them. I figured since there was metal on metal it would need grease to to function properly.
coupe11
I've greased them on other vehicles. Actually had enough rust on the 05 Silverado fronts that the brakes were no longer sliding to compensate for wear on the pads. After that I started greasing them. Nothing else goes into the salted roads in the mountains during winter so none of them have had the rust issues.
Plati
I used syl-glide.
Definately definately (rain man quote).
Is that stuff high temp?
I always buy the special little packets for brake grease.
wait .... BOLTS? grease those?
J
Jexpy97
Merica
I'm just worried they might come out of the caliper.
I only greased the smooth part of the bolt not the threaded end that screws into the caliper.
coupe11
I misunderstood. I thought you meant the pins the disk brakes slide on as the piston in the caliper pushes them.
But, I have greased bolt threads, too. After you break a few nuts/bolts off from 4 or 5 WV winters, you do what you can to make sure you can get that thing apart 3 or 4 years from now. Never had one come loose after greasing, as long as it was torqued down at installation.
