I have reverse but no drive
ExpeditionMom
Colorado
So yesterday I was driving down the highway with no problem. Stopped at a stop light went to turn left and it started to chug like it wasn't getting enough gas. Started flashing the o/d sensor and went into limp home mode. Now it goes into reverse with no problem but won't go drive forward. We read the code and it put out P0720. We then changed the output Speed sensor and it still isn't working. Fluid levels are good too. What else could be the problem???
stamp11127
Temple, Georgia
Since the fluid level is fine there isn't much else you can do at this point. Some will say change the fluid and filter but the majority of the time it is a waste of money.
Trans shop time and have the trans tested / read. That way the software will command specific events, those that fail will give an indication of the problem.
