This is the procedure for the 2007 Expedition. I would think the 2008 would be the same. I could not get the pictures to come out. I will try to save it to a PDF and attach it here.
Brake System Bleeding
Special Tool(s)
Vehicle Communication Module (VCM) and Integrated Diagnostic System (IDS) software with appropriate hardware, or equivalent scan tool
Material
Item Specification
High Performance DOT 3 Motor Vehicle Brake Fluid
PM-1-C (US); CPM-1-C (Canada) WSS-M6C62-A
Master Cylinder, In Vehicle
WARNING: Use of any other than approved DOT 3 motor vehicle brake fluid will cause permanent damage to brake components and will render the brakes inoperative. Failure to follow these instructions may result in personal injury.
WARNING: Carefully read cautionary information on product label. For EMERGENCY MEDICAL INFORMATION seek medical advice. In the USA or Canada on Ford/Motorcraft products call: 1-800-959-3673. For additional information, consult the product Material Safety Data Sheet (MSDS) if available. Failure to follow these instructions may result in personal injury.
CAUTION: Do not allow the brake master cylinder reservoir to run dry during the bleeding operation. Keep the brake master cylinder reservoir filled with clean, specified brake fluid. Never reuse the brake fluid that has been drained from the hydraulic system.
CAUTION: Brake fluid is harmful to painted and plastic surfaces. If brake fluid is spilled onto a painted or plastic surface, immediately wash it with water.
NOTE: When any part of the hydraulic system has been disconnected for repair or new installation, air may get into the system and cause spongy brake pedal action. This requires bleeding of the hydraulic system after it has been correctly connected. The hydraulic system can be bled manually or with pressure bleeding equipment.
- NOTE: When a new brake master cylinder has been installed or the system has been emptied, or partially emptied, it should be primed to prevent air from getting into the system.
Disconnect the brake master cylinder outlet tubes.
- Install short brake tubes with ends submerged in the brake master cylinder reservoir and fill the brake master cylinder reservoir with clean, specified brake fluid.
- Have an assistant pump the brake pedal until clear fluid flows from both brake tubes without air bubbles.
- Remove the short brake tubes and install the brake outlet tubes.
- Bleed each brake tube at the brake master cylinder as follows:
- Have an assistant pump the brake pedal and then hold firm pressure on the brake pedal.
- Loosen the rearmost brake tube fitting until a stream of brake fluid comes out. Have an assistant maintain pressure on the brake pedal while tightening the brake tube fitting.
- Repeat this operation until clear, bubble-free fluid comes out.
- Refill the brake master cylinder reservoir as necessary. Repeat the bleeding operation at the front brake tube.
- While the assistant maintains pressure on the brake pedal, tighten the brake tube fittings.
- Tighten to 25 Nm (18 lb-ft).
Anti-Lock Brake System (ABS)
NOTE: This procedure must be performed if the anti-lock brake (ABS) hydraulic control unit (HCU) has been installed new.
NOTE: One conventional pressure bleed cycle consists of advancing the brake pedal to its depressed position, opening the disc brake caliper bleeder screw, allowing fluid to be released into the waste container, closing the disc brake caliper bleeder screw and releasing the brake pedal.
NOTE: Performing the diagnostic program routine drives entrapped air from the otherwise inaccessible lower section of the ABS valve into the upper sections (accessible by bleeding the brakes). Subsequent bleeding removes the air from the system.
NOTE: Add clean, specified brake fluid as necessary throughout the procedure.
- Connect a clear hose to the RH rear disc brake caliper bleeder screw and the other end in a container partially filled with clean, specified brake fluid.
- Loosen the RH rear disc brake caliper bleeder screw until a stream of brake fluid comes out. Have an assistant maintain pressure on the brake pedal while tightening the RH rear disc brake caliper bleeder screw.
- Repeat until clear, bubble-free fluid comes out.
- Tighten the RH rear disc brake caliper bleeder screw.
- Tighten to 16 Nm (12 lb-ft).
- Repeat Steps 1 through 4 for the LH rear disc brake caliper bleeder screw, RH front disc brake caliper bleeder screw and the LH front disc brake caliper bleeder screw.
- NOTE: Go to the Help menu in the scan tool.
Connect the scan tool to the vehicle data link connector (DLC) under the dash and follow the scan tool instructions.
- Repeat the conventional bleed procedure as outlined in Steps 1 through 5.
- If the brake pedal feels spongy, repeat the scan tool service bleed procedure.
Gravity
- Fill the brake master cylinder reservoir with clean, specified brake fluid.
- Bleed the rear disc brake calipers.
- Place a box-end wrench on the RH rear disc brake caliper bleeder screw.
- Attach a rubber drain hose to the RH rear disc brake caliper bleeder screw and submerge the free end of the tube in a container partially filled with clean, specified brake fluid.
- Open the bleeder screw and leave open until clear bubble-free brake fluid flows.
- Repeat for LH rear disc brake caliper.
- Tighten the rear disc brake caliper bleeder screws.
- Bleed the front disc brake calipers.
- Place a box-end wrench on the RH front disc brake caliper bleeder screw.
- Attach a rubber drain hose to the RH front disc brake caliper bleeder screw and submerge the free end of the tube in a container partially filled with clean, specified brake fluid.
- Repeat for LH front disc brake caliper.
- Tighten the front disc brake caliper bleeder screws.
Manual
CAUTION: Do not allow the brake master cylinder reservoir to run dry during the bleeding operation. Keep the brake master cylinder reservoir filled with the clean, specified brake fluid. Never reuse the brake fluid that has been drained from the hydraulic system.
- Place a box-end wrench on the RH rear disc brake caliper bleeder screw. Attach a rubber drain hose to the RH rear disc brake caliper bleeder screw and submerge the free end of the tube in a container partially filled with clean, specified brake fluid.
- Repeat Steps 1 through 4 for the LH rear disc brake caliper.
- Place a box-end wrench on the RH front disc brake caliper bleeder screw. Attach a rubber drain hose to the RH front disc brake caliper bleeder screw and submerge the free end of the tube in a container partially filled with clean, specified brake fluid.
- Loosen the RH front disc brake caliper bleeder screw until a stream of brake fluid comes out. Have an assistant maintain pressure on the brake pedal while tightening the RH front disc brake caliper bleeder screw.
- Tighten the RH front disc brake caliper bleeder screw.
- Repeat Steps 6 through 9 for the LH front disc brake caliper bleeder screw.
- If necessary, bleed the brake master cylinder. For additional information, refer to Brake System Bleeding in this section.
Pressure
NOTE: Bleed the longest line first. Be sure the bleeder tank contains enough clean, specified brake fluid to complete the bleeding operation.
- Clean all dirt from and remove the brake master cylinder filler cap and fill the brake master cylinder reservoir with clean, specified brake fluid.
- NOTE: Master cylinder pressure bleeder adapter tools are available from various manufacturers of pressure bleeding equipment. Follow the instructions of the manufacturer when installing the adapter.
Install the bleeder adapter to the brake master cylinder reservoir and attach the bleeder tank hose to the fitting on the adapter.
- Place a box-end wrench on the RH rear disc brake caliper bleeder screw. Attach a rubber drain hose to the RH rear disc brake caliper bleeder screw and submerge the free end of the hose in a container partially filled with clean, specified brake fluid.
- Open the valve on the bleeder tank.
- Loosen the rear disc brake caliper bleeder screw. Leave open until clear, bubble-free brake fluid flows, then tighten rear disc brake caliper bleeder screw and remove the rubber hose.
- Continue bleeding the rest of the system, going in order from the LH rear disc brake caliper to the RH front disc brake caliper, ending with the LH front disc brake caliper.
- Close the bleeder tank valve and remove the tank hose from the adapter and remove the adapter.
- Fill the brake master cylinder reservoir with clean, specified brake fluid and install the brake master cylinder filler cap.
Master Cylinder, Bench
Support the brake master cylinder body in a vise and fill the brake master cylinder reservoir with clean, specified brake fluid.
Install short brake tubes with the ends submerged in the brake master cylinder reservoir.
Slowly depress the primary piston until clear fluid flows from both brake tubes, without air bubbles.
Remove the short brake tubes.
