They weren’t very happy with him for fleeing the scene.
They found him, police said he answered the door stone drunk. They cannot charge him with DUI but gave him tickets. I didn’t get any tickets thankfully.
You should be, though
If he were sober and wouldn't flee, you'd likely be deemed at fault
17 EL 4x2 with HD tow is rated for 9300 pounds a 4x4 is rated just 100 pounds less at 9200 pounds. You're really looking at super duty territory for 9k pounds though unless only very occasionally towing on flat ground. As others have said, payload will be your limiting factor. If you are looking at a 9k pound rv trailer, plan on 1k pounds of tongue weight. With a WDH the expedition is only rated for 920 pounds of hitch weight.
As for motors, I've owned and pulled the same 6k pound trailer with both and will say the ecoboost is the stronger motor by a mile or three. The 5.4 is a good truck motor but highway cruising with a heavy load will keep you in lower gears and pulling high rpms on any hill. The ecoboost with 3.73 gears hardly breaks a sweat but will get 8-9mpg towing so be ready for that. You'll want the EL for a heavy trailer because it will control sway better due to its longer wheelbase. All thar being said, 9k pounds is too heavy for an expedition if you plan on having anything inside other than a driver. The IRS is soft and requires a good WDH hitch to level the truck. Payload includes hitch weight so keep that in mind.
Also, are we talking about a 9k pound GVWR trailer, or is that the dry rating? Some of these larger trailers have cargo capacities exceeding 2k pounds, so if you came in at an actual weight closer to 8k you'd be a lot better off. Still a lot of tongue weight though.
