I'm Stumped
Machete
My Rig. 2000 EB 4x4 5.4L
Illinois
Time to take it to mechanic sounds like. If you want to get it running.
Matthew T
Matthew T
Skagit County Washington
Yeah, that's not going to happen for a electrical issue. I'll keep checking relays, fuses, wires, circuits and modules for issues until I isolate the problem. If it is the pats system I may have to go to the dealer. Battery and connections checked out no draw overnight. All related fuses, links and relays have been tested and are within spec. The Pat's antenna and associated wires and connections all check out to the extent of opening the antenna module to check for heat damage or broken components. So I think I'm down to the Pats Module , PCM or a connection issue between them and the PCM antenna.Now that I'm moving over to that side of the vehicle I'll also check the ground as well. As I've been chasing this down I have been finding plenty of hardware that was no hooked up correctly after I had my heater core and heads redone a couple of years ago. would not surprise me to find a pinched wire or broken connector. On to the passenger side tomorrow.
1955moose
Sounds like your on the right track. This is kinda out there, but you might want to get a copy of your chip key done at Ace hardware. Their one of the few that can do it with one key, and get it right. It's about $75.00. Is their a way guys to tell if his key has gone bad? Keep us posted, sounds like your close.
Matthew T
Matthew T
I have a new key cut hoping to pair it with the other one once I chase this down. The old key works when this is not stuck on theft mode. I've actually got it to start a few times. but it always goes right back to theft mode.
1955moose
Sounds like your Pat's thinking your a thief! We need to fix that part.
1955moose
That's the smart way. Take the extra time to go through the diagnostic steps. Then replace that part when you've gone through the full Ford diagnostic. We keep trying to instill that in members, but they'd rather be parts changers than mechanics. Anybody can swing a wrench or ratchet, but the real Tech's, do their homework, use a test light, or a volt/ohm meter. It's not only cheaper, but you feel satisfied, and smart when your done.
stamp11127
Temple, Georgia
You can hook up the battery charger to the battery and use a setting that supplies around 14.5 volts. That will take care of your voltage drop while checking the electrical issues. Once it is running you can come back to the electrical issue that is causing the drop.
Matthew T
Matthew T
OK, after a weekend of working "real estate broker", I'm back at it today for a few hours. ***** getting real, hooked up my battery charger on 100 amp starting boost. Guess what, no theft light flashing and the vehicle will start. It does die right away but, I now really think I have a short or ground fault in the circuit that communicates and powers (pats to pcm and ignition). I got a good whiff of electrical smoke from the drivers side of the vehicle under the door/front fender. Reset charger to 6 amp to top it off it's dropped .5 volts over 2 days sitting. Any suggestions appreciated.
Matthew T
Matthew T
Update, I removed the GEM/CTM modules and inspected for moisture or other damage. None present, so I checked all fuses and relays. Again everything checked out fine. Cleaned and applied dielectric grease to everything. Now that the GEM/CTM modules are out of the vehicle I will be checking ground circuits and giving the wiring a thorough once over. The GEM/CTM is a complete ***** to remove. However if you remove the side kick panel and remove the dash frame bolt, you can flex that frame a little to create enough room to make it a lot easier.
stamp11127
Temple, Georgia
The engine bay harnesses connect to the internal harnesses at the bottom of the driver side footwell / firewall. I would check those to see if any wires have burnt. They are a real pain to get to unless you're skinny.
Matthew T
Matthew T
Yeah, that's my next move. I reinstalled the GEM/CTM took the battery down to the parts store to have it load tested (it's fine). Cleaned the terminals and whatnot, and the darn thing started and ran. The idle is still wonky but the damn thing runs now. I was noticing those connectors at the bottom of the kick panel and will be cleaning all those up before I put all the kick panels back in. Ran for 10 minutes on its own with no codes present. Some of the connections for the CTM were pretty ugly. I think the 20 factory grease was cooked on pretty good.
Matthew T
Matthew T
It lives!!!!! OK, I've got this Expedition running real nice now, here is what I think the problems were and how I solved them. At first glance the crank/no start with no codes issued made the vehicle appear to have a bad fuel pump. I replaced it and was totally wrong, I didn't notice the PATs issue (flashing theft light that would go on for 15 minutes) and should have. So after throwing that part at it and deciding that at 213k miles it was a liability anyway, I started down the path of PATs, PCM, GEM/CTM or grounding issues. I checked every fuse, link and relay in those circuits, I removed and bench inspected/tested the PCM, PATs Module, PATs antenna, and GEM/CTM modules reading every manual and diagram I could get my hands on. No problems with any of those modules. The vehicle would start and run while being jumped or boosted. Battery checked out within specs and the only thing I could think of was an open ground, because the charger/booster and jumping vehicle were both grounded properly. New neg battery cable, two new ground wires and every ground I could find inspected, cleaned, greased, put back together and a squirt of paint. After I got it running I replaced the air filter and cleaned the throttle body. What did I learn? Any future PATs or PCM concerns will be addressed with a grounding system inspection first. My total parts and consumables with this saga was just under $200. I guess I spent 16-20 hrs all total on the repairs. The fuel pump quotes alone were all at $800. I think the electrical diagnosis and repairs would have at least doubled that bill. Thanks to everyone who helped with advise and encouragement.
1955moose
So it turned out to be a bad ground or 2. Look at the education you got! Glad you figured it out, knew you would.
Matthew T
Matthew T
Yeah, negative battery cable, engine to body and body to chassis required repair or replacement. I cleaned up all the other ones I could find. Runs nicer than it has in a year.
JOlsen
Orlando Florida
I had a similar issue when my inertia switch shit out on my 99. Maybe check that.
Sent from my SM-N960U using Tapatalk
