Interior rattles
Expensedition
Newport, RI
This issue is from a 2026 Expedition Tremor with less than 3000 miles. When going over mild bumps there are what sound like interior rattles coming from areas behind the front seats.
The 2014 that I traded in had no rattles except for the D-ring on my titanium water bottle, so this is really unacceptable.
I have read that there may be a rattle coming from the sunroof. I was wondering if the seatbelts for the unoccupied passenger seats were the cause.
So far I have just observed and have not zeroed in on anything.
Anyone have the same issue?
dlcorbett
Air Force
tx
Have you been able to isolate the area? Is it intermittent? Is your tag screws tight? Try to find a general location and take it to service? Probably something loose?
csnide29
Nova Scotia
I have a rattle with the seatbelt roller that is being addressed during my first service.
Any chance that's what you're hearing?
ManUpOrShutUp
PA
I don't have a 5th gen, but I have been driving Fords for 32 years and have never owned one that didn't have some sort of rattle, squeak, creak, etc. Good luck.
Expensedition
Expensedition
Newport, RI
Thanks for the input so far.
Dlcorbett: Tag screws? The fasteners are tight and exterior.
Csnide29 is pretty close to what I suspect (the passenger seatbelt rollers) since there is no load on them most of the time. I will buckle them and see what changes. I think denial has overcome my rational thinking where there is no way Ford would deliver an $85K truck with rattling seatbelt rollers.
I did kinda think it may be an issue with the moon-roof since I have never owned one having always been tasked to repair leaks in them by others that do have a moon-roof. And you know, more parts in loose fitting tracks should result in a rattle.
Like with everything else, I will find the root cause, but it doesn't hurt to sample some owners of the same product.
ManUp: 32 years? in the 70's I was a GM man, in 1980 I had a used 78 Ford F150 that I used for diving gear the same time I had my 77 Z-28 Camaro. I sold them both and bought a brand new 1986 Ford Bronco XLT. From then on it was Ford only for me. The twin I-beam suspension the F-150 was the best and the steering radius on the Bronco was second to none.
Like I said in the first post, my 2014 pretty much had no rattles. That Expedition was the best vehicle that I have ever owned.
Ford owner for 46+ years
csnide29
Nova Scotia
I'm getting a rattle from the drivers side seatbelt roller, with load on it. Can't test without cause I always have my belt on.
I suspect that it's a jiggling of the roller on the pin/bold that secures it.
It's not the end of the world, however as you noted, I expect more from a costly vehicle.
The Lincoln wasn't that much more money and I'm sure it would be unacceptable in that vehicle.
denisdrew
Nevada City ca
I had a rattle that was related to the road roughness. Seemed to come from below my right passenger side. Dealer said it was a loose plate that had to have bolt tightened up. Charged me about $200 but it fixed the problem. Too much trouble to argue warranty coverage. I don't go to that dealer anymore.
billb1000
CT
Yes-- easy fix -- the outer seat belt extension arm which is located below your hip knocks against the door when going over bumps. Easy fix is buy seat belt pads on eBay ($10) and wrap around the extension arm. No more rattles
Expensedition
Expensedition
Newport, RI
The latest update:
I tensioned the two 2nd row seat belts and the rattle is much less noticeable.
Csnide29: Agreed, we should get more for what we have paid for this vehicle. There is not much we can do to modify a safety device, a quick thought of a tighter spring would mean more seatbelt pressure which is already uncomfortable on bare skin. Maybe some kind of tensioner or pressure plate on the spool. And well you know I am not doing that. I have to look into this more because I am sure that the engineering history is there at Ford.
Denisdrew: I was under my vehicle the week that I brought it home. The purpose was to get it ready for undercoating (I posted this event here) which required me to remove all of the five skid plates found on a Tremor. The is one plate that is really thin and in my opinion it should have more fasteners in it. It might be one of the rattles Outside of the vehicle but it is not the one that I am focused on in this post.
Billb1000: I am not having that issue. I reached down and put my hand on the extension arm and it was not hitting the door during the rattle.
I will post what I find as I find it.
Thank you for your input, everyone.
Mr Big
Tampa Bay, Florida USA
I occasionally have some on bumpy roads. They come from behind the driver and front passenger seat. I can't pinpoint if it's high or low. So, it could be the pano roof cover, seatbelts, bucket seat tracks, etc.
Expensedition
Expensedition
Newport, RI
@Mr Big I am looking at ways to rule out the seat belts. It is obvious that all of the passenger seat belt metal inserts bang all over the place as I drive. The rollers, if they also contribute will be hard to modify but the the metal tab is an easy one.
I don't think it is the sun roof parts just yet. I just never... ever... wanted...glass or ports (seals) on my roof. Put that money elsewhere! but we have no choice with the Tremor option.
The seats seem pretty solid in the tracks.
I will post what I find as it gets resolved.
Thanks
aggiegrad05
North Texas
I have this. Also a Tremor. It sounds like a hollow plastic-ish rattle any time I hit a bump and it sounds like its coming from over my right shoulder...hard to place how far back. I also suspected it was sunroof but, like you, I checked and it feels pretty solid.
This morning on the way to work I did a test: I opened the sunroof all the way (press the open button a second time once its already open...it will open more). And...the noise stopped. So it IS sunroof related. The next test will be on the way home now that I have closed the sunroof; does the rattle return or did the opening "re-seat" something?
Expensedition
Expensedition
Newport, RI
Hi aggiegrad05,
I haven't responded recently but I did just what you did and I am still in denial that they sold me a truck with a moon roof that I did not want and to boot it rattles when fully shut. I am a little beside myself.... You know (Fkn Pissed Off).
The moon roof has no use at all! I have never owned a vehicle with one and in the past refused to by one that had one. Why why why......
It is a nice truck (SUV) otherwise, but this nearly kills it for me.
Time to write that letter to Ford.
Mr Big
I had an incident years ago with a bird and never opened a sunroof again. However, there's nothing nicer, especially for the passengers, than having the moon roof cover opened, being able to look out. It's even better at night. With the exception of hot days, I always drive with the cover open to expose the glass. It's really cool in the rain too.
aggiegrad05
North Texas
Hi aggiegrad05,
I can confirm that the rattle has stopped...for now.
This same thing happened on my 2018 Platy. It ratteld, I opened it, the rattle stopped, rinse, repeat, until the thing just broke and wouldnt close. I took it in and they replaced the entire cassettee (under warranty) and it never had another problem. So I'll bring it up next time I'm at the dealer.
(I am convinced there are people (like you and my wife) who HATE sun/moon roofs and find them a waste...and people (like me) who LOVE them and would never drive a vehicle wihtout one because it feels like a cave...and there are no in-betweens, ha!)
Expensedition
Expensedition
Newport, RI
Thanks for the feedback. I am trying to break down what is inside for parts and how it functions. Most workings like this have a "Park" function where it should lock up at full open or full shut. Honestly, as I am finding in the redesign of this vehicle there are major shortcomings in the body. It is like the new kids took over design and the veterans all got pink slips.
I will post more when I get back home and have some time to look closer.
The rattle is completely unacceptable.
Mr Big
I can't agree more. Coming from a GEN4 Platinum to a GEN5 Platinum was a huge letdown. I few new tech items outweighed the GEN4, but Ford really stripped the model. IMHO, in order for a GEN5 Platinum to be equal to a GEN4, one has to get the Ultimate package. They even moved the standard CCD suspension, top B&O system and 22" rims to a Driver's package.
I didn't research when I first purchased my new Platinum, Then I researched, and luckily had not picked up my first choice.
I know profitability is key, but turning a standard Platinum into a Limited or maybe an XLT with a little extra is criminal.
Expensedition
Expensedition
Newport, RI
Without removing the headliner, I inspected all of the parts in the sun roof. I also cycled the sun roof to and listened for changes in sound.
What I found was there are no obvious loose parts (No visible or reachable with fingers) however there is no doubt the rattle comes from somewhere near the after part of the sun roof, and it is loud and obvious and should not exist in a brand new >$85K vehicle.
Cycling the sun roof open and shut proved very little and it was difficult to quantify the sound difference since once the roof is open, the sound pressure is less and the outside sounds mask some of the rattle.
I find it hard to believe that I am the only person with this issue. I would think that the people that bought the more quiet versions of this years Expedition (my Tremor has road noise from the tires) would be very angry about the rattle noise.
A letter to Ford is in order.
DAJinCT
CT
There is no question there is a design flaw in the sunroof bracket that bisects the front glass from the back glass. With the shade all the way open, this bracket is very flexible with hand pressure. Any significant bump makes it rattle. A pet peeve of mine is interior rattling so I am trying to figure out a fix, but not really coming up with anything.
rico2good4u
I had the same rattling issue on 2026 Expedition Max from that horizontal plastic sunroof bracket when driving on older/rougher roads…took it in to the service center to get checked out over the weekend and they called that part of the sunroof the “water trough”. Diagnosis/repair language from service center below. Hope this helps
CUSTOMER STATES RATTLE NOISE FROM WATER TROUGH ON ROUGH ROADS
1. FOUND THE FOAM TO BE DEFORMED ALLOWING PLASTIC CONTACT AND RATTLE TO OCCUR. REMOVE SUNROOF GLASS AND REPLACE WATER TROUGH AND RETEST ALL OK AT THIS TIME
ML3Z 1654022B - WATER TROUGH 1
xojgiiox
