Intermittent low fuel and oil pressure light
Discussion in '1st Gen - 1997 - 2002' started by Travistyson1, Jul 12, 2018.
  1. Travistyson1
    Travistyson1 Active Member
    39
    32
    Feb 16, 2017
    Seminole florida
    98 expedition xlt 5.4 4WD auto
    On my way to work the fuel and oil lights were coming on intermittently. The fuel is over 1/2 tank and the Oil pressure was good. Plugged in my logger to make sure. Any ideas at all on where to start. I have had something draining my battery lately as well
  2. 1955moose
    1955moose Full Access Members
    3,035
    427
    Nov 23, 2014
    I'd get a schematic and see if the 2 share either a hot, or a ground. It's possible one of your grounds is loose, or corroded. I'll check my 2000 schematic later, although it may be different than yours.
  3. Travistyson1
    39
    32
    Feb 16, 2017
    Seminole florida
    I was thinking it has to do with the electrical system also. Considering something keeps draining my battery. Usually it has to sit for several days before going dead
  4. Don Hall
    Don Hall Supporting Member Supporting Member
    86
    86
    17
    Jun 8, 2018
    SANTA CRUZ, CA
    Batt going dead in several days is not normal. My '04 may sit for 14 days, and starts immediately.
    To check for a parasitic drain, connect an ammeter between the + batt post and the + batt cable. Pull and replace one fuse at a time, and when you see an decrease in amps, you have located the circuit causing the parasitic drain. Unfortunately, a fuse may protect more than one circuit, so more analysis may be required.
    Yes, I'm aware I haven't provided a solution to the fuel and oil lights, but the parasitic drain may be a short within those circuits.
  5. stamp11127
    stamp11127 Super Moderator Staff Member
    60
    5,215
    723
    Mar 10, 2012
    Temple, Georgia
    Check ground points behind both kick panels
  6. Travistyson1
    39
    32
    Feb 16, 2017
    Seminole florida
    Thanks guys I believe it is resolved. Checked the battery, and the ground on the firewall was loose. Tightened it up and she started right up have not seem the lights on since. I do still need to follow through and do the test to see what's draining the battery.
  7. 1955moose
    3,035
    427
    Nov 23, 2014
    You can do the same test with a volt/ohm meter set on milli amps, removing one fuse at a time. Theirs great videos online that can walk you through it.
Share This Page
