pomerjon
I started to change the brake pads on my 03 expedition XLT and everything was going smooth till I tried to compress the pistons. I took the cap of the fluid reservoir and and grabbed my c clamp and the first piston when in easy but the second piston would not budge I even bent the handle of the clamp so I was going to pump the brakes so the first piston would come back out and I could try compressing them both at the same time. When I pump the brakes the compressed piston came completely out and fluid squirted out around it, and the other piston is still rock hard. So im asking weather or not there is a way to put that piston back it correctly and get the other piston compressed? Or am I getting a new caliper?
