Is there a way to get a band-TPMS truck ('09) to recognize Ford stem TPMS ('14 F150 wheels)?
JoeZ
Overpeck
I don't know about the Ford stem tpms, but my tire guy replaced all 4 of mine with stem type (probably genaric) and had no problem programming them. Check at a tire shop, they should know. Good luck.
bloodhound
Merica
No, they are different frequency sensors. But as JoeZ stated you can get stem sensors that are the correct frequencey for your '09 to recognize.
A
Adieu
SoCal
...tried a knockoff relearn button off Amazon --- FAIL.
But then, after a while (couple days, couple short drives) the TPMS self-learned. Somehow. Light disappeared and flashing error message has stayed off.
Seems 2014 F-150 stems @ 315 mhz ARE compatible with 2009 Expedition??? Btw, interesting tidbit: center caps fit. WITHOUT rear axle trim.
bloodhound
Merica
I went through this before I got the correct sensors. The light and error message went away on it's own, then came back. Then went away, then came back. Maybe you lucked out, but I predict it will return.
