1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Issues getting refrigerant to charge
Discussion in '3rd Gen - 2007 - 2017' started by evan1234321, Apr 30, 2021.
  1. nando556
    nando556 New Member
    23
    Apr 18, 2021
    Fort Worth
    Following this.. I have a 2009 and have the same issue with AC blowing hot but it worked well just a couple weeks ago. I bought one of the cans with gauges from autozone but it just shows that it was way over-pressured. Maybe leak on the intake side so over-pressured with air?
    [​IMG]
  2. 07navi
    07navi Full Access Members
    77
    2,554
    551
    Feb 3, 2020
    Mt.Shasta California
    Self sealing cans have a valve inside so they don't let refrigerant into the air. You can get an adapter for those if you only have the pin type hose fitting or you can use the hose for the self sealing one type. They are moving towards the self sealing ones especially in California. You can save half a can until next year but now they are wanting a deposit on the cans of $10.
  3. CHRIS HODGE
    CHRIS HODGE Full Access Members
    248
    65
    May 6, 2018
    Motorcity
    System has to hold a vacuum. As Fuzz said for hours, if not, fix the leak and then re-ck.
  4. Goofy173
    Goofy173 Active Member
    57
    40
    Oct 16, 2018
    Ky
    Bad, bad leak. Obvious but may be hard to find.
  5. tommyddsr
    tommyddsr Full Access Members
    203
    135
    Jan 4, 2014
    Portsmouth, Va
    So, common leak area is the block at the back of the compressor. Also since you tried to put refrigerant in it and had gauges on it, a stuck Schrader valve is also a possibility. Other than that chasing leaks is probably best left to the A/C guys.
  6. SEPTIC PROFESSOR
    SEPTIC PROFESSOR Full Access Members
    66
    147
    25
    Jan 2, 2018
    SARASOTA
    Dude, they all fail pretty much at about this age, common known issue for guys on the forum who do their own work.
  7. 07navi
    77
    2,554
    551
    Feb 3, 2020
    Chasing leaks is not hard, just put the dye in and get the yellow light.
  8. Utah Driver
    Utah Driver Member
    52
    19
    16
    Sep 15, 2020
    Utah
    How about some pictures of your setup? Sounds like your hose coupler is not correct.
  9. max78
    max78 Full Access Members
    37
    131
    65
    Sep 15, 2018
    AZ
    If it holds vacuum for 2 minutes then it should hold refrigerant for a few minutes as well. Lets make sure your equipment is even good first.
    Check the rented gauges are in good working order. I have seen them with bent pins and screwed seals. Check the pins for obvious damage and proper range of motion. Check the seals are even there, and they are not torn or worn, do NOT over tighten the hoses to the gauge, finger tight only and not even that tight really. I have seen rented sets missing seals, or damaged. I over tightened a set and that pushed a seal into the gauge causing a restriction into the system, and a leak out of the hose. I did not tighten it that much at all, it was really easy to do.
    Out of the 20 or so times I rented gauges, 2 of them were damaged and did not work. I had a few more with bad seals that gave me issues. people around here must be really hard on stuff.
    Connect high and low side hoses.
    Screw the knobs down to open both high and low valves (blue and red). Sometimes screwing them down too much causes issues, be careful and back off a turn maybe?
    Open the blue and red knobs on the valve manifold
    (If applicable) open the center valve that is connected to the vacuum (usually Yellow).
    pull a vacuum for around 15 minutes.
    With vacuum pump running close the center valve (usually yellow) then turn off pump.
    note vacuum level on paper or take a pic of the gauge.
    Let sit for 15 minutes and look at vacuum level.
    If the gauge visibly moves right after shut off then you have a major leak. trying to fill with dye refrigerant should still be tracible because its still coming out. The Schrader valves are a super common leak point if there is no leak detected at any other component.
Share This Page
