SourMashII
Got mine also under bumper or wherever.. its a pleasure.
These fords need something like that since the drain plug is in a horrible place. My Explorer was the same way. Thanks.... will find something that will work.jrjr, the unit that I am using in place of my oil pan drain plug is a check valve with a cap on it (2 boundaries for the oil to get out). So, when you go to drain the oil, you remove the cap and then screw in this 12" piece of hose with an override tip to it. This override tip forces the check valve open, allowing the oil to drain out. They used to be really popular, but I haven't seen them in some time. It cost me like $15 at the time. It was money well spent for me.
