juan214
So boys and girls seems I developed a suspect knock. Just coincidence had my A/C serviced and ask to have it evac, flush, recharge (with oil) about two weeks ago. The only things done prior to this in order are front brakes pads, brake cables, parking brakes shoes & hardware, right rear brake line and bleed, AWD fused reinstalled, State Safety Inspection (it passed), and fuse for A/C reinstalled for prior to service. A few days after a/c service I developed a vibration/ knock. I could hear a heat shield rattle a little louder (not the issue). When I turn the a/c or heat on I get a knock. Roll the windows up or down and hold the button the strain makes the knocking noise. I turn the steering wheel occasionally get the knock. At idle it will come up occasionally .
This range of cause and effects has me puzzled. Could be a simple engine knock? At acceleration no knock, and truck seems to run as normal. It is not the typical engine tick.
No Check Engine light
Any suggestions as to what to look for would greatly appreciated. Thinking may be an EGR issue? Rod Bearing? I just heard it after start up just today.
