LED Light bar
Flexpedition
midwest
A ton of research & testing goes into air openings - sizing, location, etc. The 2018 Expedition has the largest active shutters of any vehicle on the road today. That said, there is no way in heck I'd go and block it for any reason.
benyl
Calgary
I would suggest that it would only matter when towing 9200lbs in Death Valley at 120 F at 2pm.
I doubt the cooling capacity is used running around town.
Randy Schmidt
Randy Schmidt
Illinois
These were my thoughts... I wouldn't think that only blocking 18" of this opening would effect the cooling especially with the enormous grill the Expy has.
carid
Cranbury, NJ
Installing an LED lightbar is quite a good idea to improve the light output. Here's what they did to the 2018 Expedition SEMA project:
The short light bar is placed on the bottom part of the bumper.
If you put one or a pair of shorter lightbars, they would block less air. Plus you can mount the light bar right on the bumper surface, not necessarily in the vent opening.
Usually LED lightbar sizes start with 5-6 inches.
Also there are dual row and single row configurations. View all available options on this page.
dlcorbett
Air Force
tx
Just to make clear, that light bar setup is on what looks like a modded xlt without the dap. I wouldnt put the bar in the same location if you have dap becuz theres a sensor there. I was thinking about about putting one in the space underneath the grille where it meets the bumper, however i dont think that wpuld go well when time for turn in when lease is up
BlackedOutMax
Suffolk
Blocking the opening in The grill isnt going to do anything to cooling. You’re not gonna see a drop in performance or in mpg. If you believe blocking an air flow opening in a grill is going to damage your vehicle than you are highly misinformed.
I even went as far as to remove the stupid plastic air dam under my 16 and I’ve seen no difference in the past 15000 miles
David1
Pa
You mean the snow bucket between bumper and radiator ? I have been thinking about removing or drilling large drain holes in that thing. Always curious if it would help MPG any on the highway.
Donn Brink
Hood River, Oregon
What bug deflector is that on this EX ? Purchased a 2019 and that one looks like in really blends in nice with the lines on the hood !
