Lift options?
Nokturnal
Ft Bragg, NC
What would you guys recommend as far as some cheap suspension upgrades? I'm not looking for anything huge, just something to fit my 35s a little better. I'm a rock and trail guy so I'm not looking to have my truck sitting 10 feet off the ground. Just want a lift that's gonna give me a few inches of height to help clear my tires with plenty of flexibility for the trails. Also, when I hit the trail I don't joke around, I get down with my truck, I take things that would make some men **** themselves, so if there's any weak links in the suspension that you guys would recommend upgrading to a heavier duty piece (if available), let me know.
Thanks guys =]
99 Expy
Laramie, WY
Since you have a 1st gen, we have the largest amount of options when it comes to lifts since we have a solid rear axle. The cheapest lift that most people do is get 2 or 3 in spacers to put on the rear coil springs. They are cheap off of ebay where most people get theres. I am going to do mine this summer, so I'm not sure which ones everybody gets, here is a set one guy on the site is getting
http://fordexpeditionforum.com/showthread.php?t=172
As far as the front end, if you follow your torsion bars (the long bars that come out of the back of the lower control arm) to the to where they stop at the cross member, there will be a bolt that comes out of the bottom on each bar. You can tighten those bolts up and that can get you 2-3 inches. More people will chime in and tell you exactly how to do it. I think with the TT (torsion twist), rear spacers, and a 3 inch body lift you can fit 35s on your truck, but it might rub.
N
Nokturnal
Ft Bragg, NC
Well I have the torsion bars tightened up already, I did it for a temporary fix but it stiffened up the front suspension a lot and I heard it can cause suspension components to wear down quickly and also break axles easier, so I was hoping to find an alternative. as far as the rear, I'll probably just go with the spacers.
and its a 99 4wd with 35x12.5s on stock 17s btw
99 Expy
Laramie, WY
I have always wondered how much extra wear it puts on all of the suspension, and I'm sure its more than when set at factory, but lots of people on here have it. I'm not sure of other options than getting a lift kit, you would have to talk to the people that already have lifts, and see what they do or don't like about their lifts.
jacks3am
michigan
go with a 2 inch body lift because the three inch is too much In my opinion. then a 2 inch rear spacer and do a torsion crank of about 1-1.5 inches and get extended shocks!
KWT2000
NINE MILE FALLS
with the 2" bodylift... you will have to make custom bumper brackets so they look right with the 3" they come with the kit
jacks3am
michigan
^^good call. i just said it because a neighbor had a 2inch on his f150 and it was beastly
N
Nokturnal
Ft Bragg, NC
The only thing though is that the place that I'm rubbing is on the frame. The body lift wont help me clear that. If I get wheels with a different backspacing do you guys think I could get rid of the frame rub? If yes, what backspacing would you recommend?
junior73
South Carolina
If you get a wheel that has negative offset, it will push the outside lip outside the wheel well. If I remember right, the factory wheels are +44, which pulls them into the wheel well, and closer to the frame. A negative offset will push them further out, and away from the frame.
Here's a good calculator for the offsets:
http://www.1010tires.com/wheeloffsetcalculator.asp
KWT2000
NINE MILE FALLS
If you go with an 8 or 8.5 wide wheel with the stock backspacing which is 4.5" you will be fine the stock wheels are only 7.5" wide so that is where your problem is... theres a few of us here running 8" wide like my self and LANE24 with no problems
walnuts4x4
Watertown, NY
remember an inch more and you would be a king.... an inch less you would be a queen.... :greenchainsaw:
but along with the bumper brackets... if you are gonna spend the time and money to lift your truck go with 3"... cuz if you do 2 it might not be enough..
panda24619
San Diego
ive had my tt for idk. almost a year or so now. and nothing bad. i have no right sway bar now, but not a big deal. im gonna order spacers after i get my check and thatll be all for me for now. if you want some real good advice on wheels log on to f150online and post a question in their wheels/tires/brakes section. a guy named wadell, (someone invite him, hes got an expo too!) and hes the wheels expert! i think what you want is a 16 17, what ever size rim, x10 and with a 4.5" back spacing. so a 16x10, 17x10 18x10, what ever wheel you want. and with the 4.5 back spacing. i think when i get my walker evans im going to go with a 3.5 or 3.75 in backspacing to give me a wider look.
