Liftgate
ExpeditionAndy
Fort Wayne, Indiana
Yes my problem is when I press the button in the handle, it does not unlatch.
This is the part number for the liftgate handle 8L1Z-7843400-AAPTM. You can get it here https://www.fordpartsgiant.com/part...=luggage-compt-tailgate-lock-controls,,<43400 for $130.86 You have to paint the handle to match your truck color.
Before you buy the handle, I would make sure that you check everything out make sure you are getting power to the switch. I would probably bypass the switch and close the contacts where the switch plugs into. If it unlocks the latch then the switch is bad, if it doesn't then you problem lies somewhere else.
ExpeditionAndy
Fort Wayne, Indiana
chart75
Denver
Did you try a reset on it? Disco the battery for 20 seconds, reconnect it, see if it works. My wife's stopped working recently which turned out to be a bad strut along with a not so great lift rod.
chuck s
When did the liftgate handle change? I don't recall a button of any sort in my '07 handle. Just pull the whole handle to unlatch the lift gate. There's a button in my '17 handle as this vehicle has a power liftgate. Frightened my wife the first time! :)
-- Chuck
ExpeditionAndy
Fort Wayne, Indiana
-- Chuck
The 2nd gens had the articulating handle. I'm not certain, but I think it changed with the 3rd Generation.
deweysmith
Montreal, QC
I think so, and even the non-power liftgate still has the electronically-actuated latch. You push the button and a motor unlatches it for you, even if it doesn't lift it for you.
Basically the non-power version behaves just like the power one does with the power liftgate setting on OFF in the computer. The remote button unlatches the glass, etc.
chuck s
On my '07 XLT there was no electrical locking or unlocking of the lift gate. The glass window had an electric remote unlock that seemed to get hit in my pocket as I occasionally got the "lift gate or rear window ajar" notation on the dash. Was locked/unlocked with the doors.
Had to physically pull on the lift gate handle to open it which is what startled my bride with the '17.
-- Chuck
ExpeditionAndy
Fort Wayne, Indiana
-- Chuck
I wonder if that was an early build 2007 Expedition?
Allan E Joyner
Fl.
I had issues with my power liftgate 2011 el xlt it was the shock supports on the sides it keeps closing on me as soon as it opened. If it's not even opening under power and it is staying open manually then that's not your issue. It's either the switch to the liftgate motor or the mechanism itself I think. That's the part that's expensive. I got lucky and replaced both shocks on mine and only cost 48 dollars.
I
Napa
Thanks to all who commented. I solved my problem. I replaced the handle release switch and now my liftgate handle is working properly. $20 fix from RockAuto parts. Took less than 10 minutes to replace(I already had the tailgate interior panel removed)
