john2017
I tried the manual with no luck. Can you limit the opening travel on the rear liftgate so it does not hit the garage door?
I didn't know that. I just assumed that they all would be adjustable. I didn't try it with mine because it was too cold out last night and I didn't feel like going out. I had a 2006 and a 2009 Mercedes ML 350 that allowed you to adjust the height of the lift gate.Thanks for the link. I had a 2015 Explorer so I am familiar with this procedure. But does not work on my 2017 Limited Expedition. Hard to believe the liftgate opening height can not be adjusted.
I suspect that the real issue is that its a 14 year old platform that doesn't allow for many of the newer technologies. With the 2018 will come a host of new technology and I suspect some of these issues will go away. I like my 2017 and I tried to adjust the liftgate and found that I could not adjust the travel.I like the Expedtion - but it is clear that Ford shortcuts many features, when compared to other manufacturers.
and stick you tongue out, whilst closing your left eye.I suspect that the real issue is that its a 14 year old platform that doesn't allow for many of the newer technologies. With the 2018 will come a host of new technology and I suspect some of these issues will go away. I like my 2017 and I tried to adjust the liftgate and found that I could not adjust the travel.
It could be something stupid, like, open the liftgate, set it for the height you want, lock and unlock the doors 5 times until the horn beeps, then turn on the headlights while pushing the close button the dash while putting your foot on the brake and moving the drivers seat to the rearmost position.
yes there is....
it will stop when encountering resistance, then will reverse.
i have closed it on myself a time or two already and it squished me then reversed.
