Hi all! Thanks for having me here. So I have a 2017 Expedition Limited that recently lost it's brakes as my wife was pulling in to the neighborhood (luckily not on a highway but still scared the crap out of her). Some research and troubleshooting found that there is an issue with this year range for the master cylinder failing and leaking all the fluid in to the booster. I pulled the vac line off the booster and discovered there was indeed fluid in the booster. More research and I found that there is actually a recall on this for my year range. However, a call to my local dealer and to Ford revealed my VIN is not included! Frustrating since you would think they want to know about this issue happening to other VIN's, but they did not seem to care. So I replaced the master cylinder and booster myself (booster was full of fluid), bled the brakes, and now it seems to be working fine. However, I now have the little wrench icon showing up and the code is C109D-20 "low vacuum condition detected". But, as mentioned, brakes feel fine, engine is smooth, no issues. I pulled the switch out of the booster after a night of sitting and it was definitely still holding a vacuum, so I don't think there are leaks at the seals or in the lines. I was thinking the sensor right there at the booster went bad? I was going to try it, it's only $30 from the dealer, but figured I'd ask here first and see if anyone else has had this issue or had any ideas? Thanks in advance!
Ryan.
Ryan.
