I am hoping someone here can give me some insight. I have searched high and low and watched most of FordTechMakuloko's videos on the subject but can't find what I have going on.
Some background: 2007 2WD with 204,000 miles running Motorcraft 5w30 for the last 3 oil changes and 5w20 before that.
I was finishing a 2 hour highway drive when the truck went crazy as my wife put it pulling into a parking spot. Multiple misfires, cam/crank correlation code, no power, etc. Drove it cautiously back home and started tearing into it. It was due for an oil change and tune up so I started there. During the last 6500 miles it managed to burn though over half the oil!! I have never had that happen before, and the plugs were all shot even though it should have had about 15,000 more miles based on the 100,000 change mark (changed originally around 125,000). Changed all plugs and coils and the crankshaft position sensor just for S&G. Checked compression also and was sitting in the 165-195 on all cylinders.
Started it up and still have rough idling, struggling with power and what seems like hard shifting. But, only a P0018 code. Mode 06 on my scan tool shows no misfires and no misfire code thrown after multiple drive cycles and warm ups and cool downs. Only the P0018. I changed the VCT on the drivers side (which from what I could find is the P0018 side) about 10,000 miles ago.
I am feeling like it the timing jumped a tooth issue, but everything I have found says you would also have misfires, and hard starts, which I have neither. I was thinking about swapping the camshaft position sensors, but FordTech said those never go bad, so I figured it was time to break down and ask you guys. Thanks for all the help, this forum has been a lifesaver on multiple occasions.
