steelfan247
I have a 2003 Ford Expedition (E.B. Edition) 5.4 4x4 188,000 miles
Need some help and advice please...
I was coming home and I felt a loss of power all of a sudden and instantly a low oil pressure light turned on which directly following that my engine shut off. I checked my oil dipstick and it was a little low on oil but still reading on the dip stick above the low refill line and looked clean. I then started it and all seem fine placed into gear and resumed driving another mile same thing happened. I was less than a mile from my house at this point and restarted it and made it back to my garage as doing so light came on again and the engine shutdown again. I then decided to give it an oil change and inspect the oil. After inspecting the oil there was a small amount of shimmer to the oil this being signs of very vary small flaky metal dust within the oil that was draining. This getting me very worried about internal engine damage. I refilled the motor with 5w-20 synthetic blend motor oil and used a Mobil 1 Oil filter as the first oil filter I used was a Fram extra mileage oil filter which I'll never use again I'll be using Motorcraft from here on out. After doing the oil change I then restarted the engine it started and sounded good at idle no lights came on and could sit there and not have an issue, BUT as soon as I placed it into reverse instantly low oil pressure light came on and the oil pressure gauge dropped as it did before but this time doing so instantly once placing into a gear and could hear some engine noise not wanting to rev it up much but being able to and doing so slightly it would rev and gain RPM's but sounded like there was engine noise. I was literally just sitting in my driveway and placing it into gear as soon as I place it back into park oil pressure would return to normal and no more engine noise. The noise does not occur in park and the oil pressure gauge is at normal mid point and no low oil pressure light is on (the light is not on) but when placing into reverse or drive it instantly looses oil pressure and light comes on and any rpm rev results to engine noise.
Looking for some advice. Always ran good prior had no signs of anything wrong until now.
Steps I'm looking at taking to try and figure out what's wrong...
1. Going to do a pressure test today after work.
2. Results might change after pressure test results but most likely drop the oil pan and check to see if the oil pickup screen is plugged.
3. Oil pump failure not sure how to determine but sounds like their a pain to replace.
Not sure if this is the correct steps but figured its a good start...
Also it seems that changing the oil sending unit would be something that would not help as there is a for sure loss of oil pressure due to noise being heard from the engine when loss of oil pressure occurs and the low oil pressure/high temp light turns on when going into drive or reverse.
Also could a crankcase sensor be a culprit in what is going on? My gut tells me it's either the oil pickup screen that's clogged or the oil pump has failed or it's both the oil pump failing has led to the oil pickup screen clogging up due to engine damage occurring?
Any advice or expertise would be very helpful and I'd be very grateful for anybody's feedback about this subject matter. Thanks in advance.
